Will brake calipers from a 2016 Sport model fit on a 2016 Rubicon?
RWPL
Southern California
I purchased 2016 take off Rubicon axles to swap onto my 2016 Sport. Does anyone know if the Sport brake calipers will work on the Rubicon rotors?
Thank you.
From my point of view all of the calipers are identical. As for the axles, when you say swap, make sure they are both D44's and then verify what gear ratio was installed in them. Hopefully no one changed the gears as they should be 3.73, 4.10 or better at both ends.
