You didn't say if you have a 2dr or 4dr. With the 2dr there were differences in the soft tops but I believe if you get all the correct brackets it will work on the 2010. They may be the same anyway, I don't recall exactly when the changes were made... Maybe 2010 was the start and then some additional refinements in 12/13? If you have the header, door surrounds, roll bar brackets with the '16 you should be good to go, however.
