Ya the road noise drowns it out a bit. Turn it up or try headphones, but you will hear a squeeking the goes on for most of the clip.All I hear is what sounds like road noise.
It happens only when braking. As soon as I take my foot of the brake or the Jeep stops moving it stops. I don't know enough about brakes and I've never heard this kind of noise before. My suspects: warped rotor, something with the brake pad, or slightly bent axle causing the rotor to contact the brake pad unevenly.Is it a squeak or the brake pad wear metal piece?
About the only other thing that could make a noise when moving would be the hub unit bearing.
If it were a warped rotor you would feel your break pedal pulsate. Have your breaks inspectedIt happens only when braking. As soon as I take my foot of the brake or the Jeep stops moving it stops. I don't know enough about brakes and I've never heard this kind of noise before. My suspects: warped rotor, something with the brake pad, or slightly bent axle causing the rotor to contact the brake pad unevenly.
It's easy to hear in the Jeep, but Apple tries to "help" the recording by automatically turning up the microphone gain until the background road noise drowns out the brake sound. Maybe there is an app that will help make a better recording.
