2012 Rubicon. Getting C2101, C2103 & C102B when braking hard. The battery, ABS & traction control light come on, but can be reset when turning off/on. Changed the wheel speed sensor and connector (I broke the connector). I can see the voltage spike to around 16 volts on a graphing scanner when I brake hard, but goes back to normal immediately (just a spike). Someone has added a lot of extra lights. I disconnected those, to no avail. The TIPM and alternator have been replaced. I added ground wires, frame, engine, body. Also, get the same issue when I pulled all the fuses related to the ABS and shut off the ABS temporarily with a JScan. The wheel bearing feels good. I've read all the other threads and am completely stumped. TIA!
