Transmission RPM goes up will not shift and ABS, brake, and traction light is on
Akcm1977
Timpson tx
Brake light comes on and then trans rpm goes up. Will not stift. Abs and traction light staying on. It is a rhd with a new wiring harness, put in in August.
Are your grounds clean and tight? Maybe even add a extra one, most electrical problems can be bad ground.
Did this happen after installing a new wiring harness? If so, I too would think it's related to a ground issue or a connection that could have not been plugged in on accident.
