Toyo RT open country tire pressure?
Allwhite14
Florida
I just picked up a 2014 wrangler 4 door. It has toyo RT open county 33x12.50x20 tires. It rides rough. The pressure is set at 50 psi. Seems a little high. What pressure should I be running? Thanks.
It's rough because you've got too much wheel, not enough sidewall, and too much air pressure.
I run 35x12.5x18 Toyo MT Open Country on both of our JKURs, at 25-26PSI.
Reactions: Allwhite14
Running my 35x12.50r17s at 28 psi currently. Check your tires with a good gauge. Most pencil gauges are worthless and highly inaccurate.
