I have an 08 2door Sahara. About to pull the trigger on a 2021 Aliner Scout. (Maybe, might go used). Dry weight of 1340lbs I believe . Any problems towing with a 2dr?
You'll be fine, although it is a single axle. The quoted towing max is 3500, but with people and junk in the Jeep, 2500 would be more realistic. The Aliner goes around 1700-1800- no problem, just be cognizant of how much stuff you load into it or your Jeep.
