Tire pressure alert—5th tire has been deleted
Mprezioso
Ohio
I deleted the wheel on the back and I am pretty sure the absence of that tire is causing the tire pressure sensor to light up. All the pressure in the remaining 4 tires are good. I've tried resetting it but it just comes back on.
Any ideas?
I have read where you can take a TPMS with the right frequency and put it in a PVC tube with ends on it and the put the right amount of air in it and carry it in the rear of the JK and no more alarm.
I would get the JScan to turn the system off. You will find it is easier to make other system changes than using the on board system of key fob buttons and door lock switches that do not always work.
Reactions: MacGuyver
Best thing I ever did was disable the TPMS bullshit entirely with J-Scan. One more stupid electronic nanny you don't need.
