Swapping stock radio for 730N
stumpy55
pewaukee, wi
I have a 2018 wrangler and i want to swap the radion with stock radio with nav. I believe its a 730N. My main reason is I want to add a backup camera. I'm told the install is easy but I have to take it to a dealer to have it programed. Any input is appreciated
Yes, I believe it's plug-and-play, but the dealership will have to program it.
Personally given how shitty the stock radio is (even with nav), I would opt for a nicer aftermarket one, which also won't need to be programmed.
Been told by a Jeep dealer (central VA) that unless Jeep PCM was programmed from the factory for the features that your new radio has...it will not work (this is assuming the original radio did not have NAV). Was also told that the 730N will only process MOPAR rear camera data (aftermarket camera video will not be processed). Something about CAN bus speeds.
