Superchip issues
Blackjeep12
Utah
Anyone here have issues with trail dash 3, I’ve put in my modified tire size but having issues with the corrected speed. I’ve been using a speedometer app and when I travel by the dot speed signs they match up, but my corrected speed on the trail dash will have a 10 mph difference ( it says I’m going faster than I actually am).
Has anyone had these issues?
I haven't had the issue personally, but here are a few things you might want to check:
1. **Tire Size Input**: Double-check that you've entered the modified tire size correctly in the settings. Sometimes even a small typo can throw off the calculations.
2. **Calibration**: Ensure that the unit is properly calibrated. Some devices will require a calibration procedure after changing tire sizes.
3. **Firmware**: Make sure your Trail Dash 3 is on the latest firmware. Sometimes updates can fix bugs or issues related to speed calibration.
4. **Resetting the Device**: If everything seems correct, try resetting the device to factory settings and re-entering your info. It might help resolve any glitches.
5. **Consulting the Manual**: Refer to the user manual for troubleshooting tips specific to speed correction issues.
6. **Reach Out to Support**: If all else fails, consider reaching out to the manufacturer's support for assistance. They might have additional insights or could help troubleshoot the issue further.
Reactions: tJKrider
I’ve been looking into speedometer calibration, have you ever done one?
Reason being is that I recently started having to commute to work and noticed that the speedometer on the jeep is also off, as I am using stock wheel and tire to try an save $$$ on gas and the speedometer in the gauge cluster is also off by more that the super chip
Write your reply...
