Suggestions on replacement carpet options
Ok, looking at this I'm trying to figure out what it is.
My reason is that in all the media that is out now about the new Bronco one thing that stood out to me is that it doesn't have carpet, it has rubber or some such.
A light went off and I've been poking around the internet in order to replace my hated carpet... The husky hair loves the carpet, and for that reason I don't even remember what color it is anymore.
So for those that have this what is the actual texture. It looks as though there is a couple different versions. I want the sound and heat protection, but not have to worry about dog hair threading it's way into carpet or carpet like stuff.
try using compressed air to remove dog hair from carpet it seams to work okay with my lab`s hair
I have two huskies and the hair war is constant. Anything I can do to make it easier is another battle won.
It looks like the two products are bedrug and bedtred. The latter being close to spray in bedliner. Which is what I'm looking for,
@Largehit71 am I correct about that assumption?
There's a carpet style version: BEDRUG and a rubberized version: BEDTRED.
I installed the rug version in the front cab of my TJ and the rubber version in the rear. Good stuff. Tough too and easy to fit and remove.
nice.
How is the fit? I saw a review where the drain holes didn't line up.
It has the look of spray on . It cleans easily and water mud and hair are no problem .
Ok, I'm ready to pull the trigger on something like this, but it looks like this stuff doesn't have any sound deadener, or drain holes. Is that correct?
The other option that I'm aware of, but costs quite a bit more is Armorlite.
https://goarmorlite.com/products/front-rear-flooring
However, it has sound and heat insulation built in, as well as water drainage. Has anybody used this?
I put BedRug in my old '08. I think it's "okay". The fit wasn't as good as I would have liked for a floor covering, but that was several years ago... maybe it's improved. Very durable. Don't recall if it had sound damping/insulation... I think so.
I would almost rather put some B-Quiet/brownbread down in strategic places, affix insulation as appropriate and spray it.
