Strike plate door hinges
Leguaros
Vermont
Hey guys, I replace my door hinges on my JKU a couple weeks ago. Everything lined up in space sounds good but I am hitting the strike plate. Is there a way to adjust that strike plate and what tool do I need to use to adjust it?
I believe or assume you mean the strike hoop on the pillar. You can use a torx bit to loosen and move the plate around for adjustment. I don't remember the torx size, but it is big. When I swap my half doors from full and vice verse, I have to adjust the two front doors slightly. You can fine tune it too to how tight the door shuts, seals, etc..
