Stock Electric Lockers - Rubicon
CC172
California
I have a '07 Rubicon JKU with stock drivetrain. The electric locker in the rear is inop and I don't know why. I'm getting 12 volts to the rear locker but its not engaging. The front does engage though. And all lights on the I side reflect the true operating condition, blinking vs solid lights. To try and narrow down the fault I OHM'ed out the rear locker and don't have continuity between the two leads going into the diff. To try and get a baseline as to what the resistance values may be on the electric locker, I checked the front locker. To my surprise I get nothing....WTF Over?!?!?!? This makes no sense to me...electrons needs to flow, so why does the front work and the rear doesn't, but neither have continuity across the leads.
Thanks!
They are basically electromagnets so you should be able to ohm them out. I believe there are 2 plugs on the locker, one for power and one for the indicator. Are you sure you ohmed the correct one?
