Hi,
Mrs just bought a 2008 Rubicon 3.8 manual.
Original fan died from water ingress.
I replaced the fan with a Spal 16" 3000cfm fan.
Since replacing the fan I have this issue:
Start engine, turn A/C on and fan powers up in low mode. If engine is warm enough the fan starts in low without A/C on, as per normal operations.
After 30 seconds or so, MIL or CEL light comes on, fan goes to high speed. Scan of code indicates P0480, fan control circuit.
I have checked the fuses, checked both low speed and high speed relays.
Replaced the coolant temp sensor.
I've ran live diagnostics with JScan and the fan is kicking into high mode even when engine temps are as low as 70 degrees Fahrenheit.
Once P0480 code is triggered after 30 seconds of running, fan remains in high continually until you shut the engine off.
Has anyone ever had this before?
What could be triggering the ECU to send the high speed ran relay on when it's not hot?.
Any help would be appreciated.
Craig
Craig
