Several codes no symptoms
mrlou88
Irmo, South Carolina
I put a new 3.25 inch lift kit on my 2011 jk rubicon unlimited my esc light went crazy but went away after an alignment. Now I have 4 codes but no symptoms. U0141 two of them C123F and U0146. Anyone experience this or have any ideas?
Is your steering wheel straight when going straight down the road?
When driving straight do you have to keep turning your steering wheel back and forth to keep going straight?
Sometimes when the ESC goes on it's because the steering wheel isn't centered, might try centering it up and see if that makes a difference.
Reactions: tJKrider
Definitely get your steering wheel back to center. That should eliminate your C123F code. A bad ground on the battery or one of the grounding straps can cause the other 2 codes.
