Sup guys and gals. I just finished replacing the rear axle bearings and seals in my 07 rubicon. The rear right wheel was chirping when going around 35 to 40 like the wheel was wobbling. Tire speed corresponding. When I put the bearings in.. that particular side, the bearing just kinda slipped in. Took a little tapping but nothing like the left side. It had to be knocked in. I put green lock tight around the bearing race and shoved it together.. well it's still chirpping and both side have a minute wobble with a clunking sound when you push on the top of the tire.. I'm getting ready to replace the axle itself due to the tubes being worn out I'm guessing.. opinions? Comments ? An axle is expensive
