Has anyone had success installing this light bar with bushwacker fender flares? It is simple plug and play with the OEM fenders, but not so simple with driver's side indicator light on the bushwacker flares. Can anyone assist? Thank you.
What's the issue with the Bushwacker flares? How does it connect to the factory fender flare side marker light? Just a plug I assume? If so, you should be able to cut the plug and tap the wires into the Bushwacker side marker pretty easily I would assume.
Correct. The prerunner lights have plug and play with the OEM fender's indicator lights. I think I am just going to splice into the Bushwacker flare wiring. Thank you for taking the time to respond.
