2013 JKU. Replaced lock actuator on driver front door. Still doesn’t work. Check for power at the plug and we have power. Just to double check took out rear door actuator and test in front door. Still doesn’t work. Put the front actuator in rear door and it works. So what else can it be. Power is getting there and all pins are in connector. About to pull out what little hair I have.
