P0301 and p0300
<blockquote data-quote="Duster" data-source="post: 459765" data-attributes="member: 20812"><p>You say that you found out the cause of the code was a bad fuel injector. How was that discovered? The initial code says cylinder 1 was misfiring, while the second, P0300, indicates the problem has spread, and now is happening randomly among the cylinders. Do you know how many miles are on the plugs, coils, and wires? It sounds as if the original repair might not have worked properly.</p></blockquote><p></p>
[QUOTE="Duster, post: 459765, member: 20812"] You say that you found out the cause of the code was a bad fuel injector. How was that discovered? The initial code says cylinder 1 was misfiring, while the second, P0300, indicates the problem has spread, and now is happening randomly among the cylinders. Do you know how many miles are on the plugs, coils, and wires? It sounds as if the original repair might not have worked properly. [/QUOTE]
P0301 and p0300
