Overnight dead battery
Field artillery
Tennessee
2015 joy shara aftermarket led headlights. After a day with all doors off. Parked inside. Go to start the next day. Dead battery. Was not a problem till leds was installed. It’s even dead AFTER all doors are on and shut. With the key in the in the ignition. The headlight switch in the auto selection. The leds was pro installed. Not harness was hacked into. Any one have a clue??
Is the battery the original from when it was new? Could just be a coincidence that maybe the battery went bad just when you did that.
New battery this year.
if the headlight switch is in the off position. Key in place not a problem. However I just replaced the turn/headlight switch. With a new one. Because it was making the dash light and radio screen flicker.
