Oil pressure light /limp mode
JakeGreenJK
Goodrich,MI
2013 Rubicon 3.5" JKS lift on 35"s.
Bought 2 months ago. 55000 miles on it.
Keeps going into limp mode(will not go over 3000 rpms. Check engine light says low oil pressure.
I have replaced oil pump, oil pressure sensor, ran a manual gage for oil pressure so I can see it, which gets up to about 45 psi. I cant figure out what to change or fix next? Or what the problem is. Maybe the computer??
Check for a bad spot in the wire going to the sensor. Does the wire fit tight on the sensor?
Did you use a OEM sensor?
