Oil change and check engine issue
<blockquote data-quote="kk2010jk" data-source="post: 443882" data-attributes="member: 20385"><p>You need the Code, could be way to many things going on. As said - first check oil level, very, very important. Is the jeep running ok?</p></blockquote><p></p>
[QUOTE="kk2010jk, post: 443882, member: 20385"] You need the Code, could be way to many things going on. As said - first check oil level, very, very important. Is the jeep running ok? [/QUOTE]
