OEM Lug Nuts With Pro Comp Wheels?
Fairygrl33
CA
I just purchased Pro Comp 05 series for my JK, and I have been hearing mixed info on the lug nuts. Anyone use their OEM lugs or did you purchase the aftermarket lugs?
I would recommend aftermarket lugs -specifically 6 or 7 spline- they tend to be thinner and fit better inside aftermarket wheels, plus the splines require a special key socket to take off so they act as a sort of lock for your lugs.
They do make taking your tires off a bit more of a chore though :ROFLMAO:
Reactions: Chris
definitely aftermarket spline type. And then never take the tool out of the jeep except to use.
Also if you have work done on it, make sure the mechanics know where the tool is. Super easy way to piss off the your mechanic is to leave the tool at home or hide it.
Reactions: R0NAN_4x4
