First time posting. I hope I will explain the issue well. 2008 Sahara Wrangler Unlimited w/ 3.8L V6. I took it into the shop to have the head gasket replaced and the valve cover gaskets as well. The work was completed but the mechanic said he suspected that the catalytic converter on the driver's side was clogged. I took it home and ran it for a while and checked the cats with a thermogun and the passenger side was 350ish and the driver's side was 600ish. So i determined that I need to replace that cat. I ordered an entire new system starting from the manifold all the way to end including the muffler. I also replaced all four O2 sensors. After installing I reset everything and all seemed to be good until the check engine light came on. I had it checked and it was reading high voltage on the downstream driver's side. I took it back to the shop and asked them to confirm my suspensions and if it was right, replace the sensor. He got the same reading when he checked it. However when he replaced the sensor it didn't fix the problem. He then replaced the cam shaft position sensor and connection and the spark plugs and nothing changed. He has 35 years experience and said this has never happened. He spent two days trying different scenarios and still the same engine light with the same code. I tried the original sensors that I took out and still have the code. Nothing we've tried seems to work. Any suggestions?
