No Power Passenger Side Front Door?
Hsnopi
usa
Hello All,
I wanted to check here to make sure I wasn't missing a common issue before I went down rabbit holes.
2015 Wrangler JKU. Doors were off all summer. We just put them on and the passenger side window and power locks on the front door do not work. All the other doors are fine. I checked the fuses just in case but no issues there. The wiring connection was pulled and reconnected a couple times to make sure it was snug. No Joy.
The door was never dropped or anything. No tension, as far as I can tell, on any of the wiring. I am suspecting a loose connection in the harness but it's odd that the door gets no power at all. I don't know if there is a common power line to the door that runs the locks and windows. Anything I should check before jumping in? This is my wifes daily driver. (hell of a sweet daily driver if I do say so myself! )
Thanks!
Hsnopi
Reactions: franka548
I have a similar problem with the front RH door except it's intermittent. If I jiggle the harness sometimes I get power back. Haven't dug into thus yet, but if I find out what it is I'll let you know!
I wish I could help but I've never had my doors off. But what I can suggest is to take a volt meter, disconnect the door from the wiring harness and see if power is available at the plug on the jeep side when you try to raise or lower the window or operatethe door locks. This will tell you if the issue is in the door or farther back in the jeep. You'll know which rabbit hole to go down.
Reactions: TROY66/68 and mrjp
