Hey, new Wrangler owner here. Just picked up a 2010 Unlimited Sport 4 door with roughly 150k on it as my winter vehicle.
I have p0430 - replaced the driver side manifold as it was cracked, still showing the code so I assume it’s the cats.
1st question, should the 2010 have 4 cats or two total? Replacement systems show both setups, mine currently only has 2 (1 on each side) none up by the manifold.
My second question is I had a right wheel speed sensor code and abs lights, found the sensor broken off and replaced it, I still have u0125 and u1003 showing, I only took a quick ride around the block, unsure if it take more to reset
Any help would be greatly appreciated
