More new Jeep questions
What is an air blend actuator?
It's the small electric motor that controls the air flow as controlled by the temp knob.
As for the rear main seal leak, I’m guessing it was obvious? Spots on the driveway?
Yep. Just a couple oil drops on the concrete. My driveway doesn't have the first oil spot on it, so when I saw a couple, I crawled underneath. Cleaned everything up, took it out for a drive and crawled back under to see where it was coming from.
Reactions: KSwanson and mrjp
You might find getting information off your window sticker easier to read than the build sheet, I've attached yours for you.
  • WindowStickerPDF (5).pdf
