Misfire
CrazyOne73
Texas
So I have been getting this P0304 misfire code for about 6 months now. I have changed the spark plugs twice, changed all the coil pack, changed the vacuum pump, done a compression check, done a pressure test on the fuel injectors, and done a vacuum leak test and till keep getting the code. The crazy thing is the check engine light comes on and the engine idles rough and runs rough for about 1.5-2 weeks and then the light goes out and idles and runs smooth. Then the light comes back on again and starts all over again. I have also gone as far as replacing the ECM. Any suggestions or advice would be great.
Have you tried putting some gasoline treatment?
Have you cleaned your grounds?
Did you use OEM Plugs and Coil Pack?
