Max tire size for stock 17 wheels Unlimited 4 door
<blockquote data-quote="WestCoastDan" data-source="post: 464152" data-attributes="member: 23120"><p>I used JL wheels and the 285/70-17's on our 2015 Rubicon w/o a lift.</p><p>I had to install spacers on the bolts are the stops as at full lock I was getting a slight rub on the sway bar.</p><p>Adding the spacers reduces the turning rotation SLIGHTLY, but not enough to be an issue in normal driving conditions.</p></blockquote><p></p>
[QUOTE="WestCoastDan, post: 464152, member: 23120"] I used JL wheels and the 285/70-17's on our 2015 Rubicon w/o a lift. I had to install spacers on the bolts are the stops as at full lock I was getting a slight rub on the sway bar. Adding the spacers reduces the turning rotation SLIGHTLY, but not enough to be an issue in normal driving conditions. [/QUOTE]
