Hey guys,
After doing a bit of research, I'm starting to believe I might have a pretty unique situation regarding my steering system. I've got some really loose steering after upgrading my ball joints and steering linkage. I've ended chasing my tail around the steering linkage and replacing anything and everything that can cause loose steering. so far i have replaced ball joints, tie rod, drag link, track bar, sway bar bushings, steering gear, tried adjusting the steering gear and flushed the system.After all that, it's still hard to control. I have not replaced the steering pump, the steering shaft/column, or the stabilizer. Any recommendations regarding where to go from here would be much appreciated.
