Lift needed to fit 35" tires
Hi guys new to the jk and I’m trying to decide if I want to do a puck in the front and trim fenders or lift to fit 35 inch tires has anyone done the puck and how does it where after? Does it rub bad or are you able to flex out?
What are your plans for the JK? Is it just a DD or a Offroad machine, flattop fenders will gain you a few inches along with the puck you might be good for a DD. Depending on a lift and how high you go you can run into alot of money.
Your Rubicon should have 4.10 gears and with 35's you should be ok for a DD. You'll also need to recalibrate your speedometer.
Reactions: mrjp and Lxxtsy
It is a dd and I have I build plane for 40’s once it is not. I am just trying to be able to do some snow wheeling this year and follow the friends running 37+ and get to camp.
I have pucks and am running that exact tire size. It was like that when I bought it. I have not done any heavy off-roading but can’t imagine it being an issue even if I did. Have only had my Jeep for a few thousand miles but all is good. I was honestly going to switch the pucks out for springs but can’t come up with a reason to spend that $$.
