LED Rear tail light bulbs
BVlads51
Illinois
I had a turn signal bulb burn out and I decided replace them with LED ones. They worked fine when I installed them in the harness, but now the dash says both are not working and they’re giving the old fast flash despite the fact they are fully functioning. Any ideas?
You're going to need to wire a load resistor into your harness. I also suggest getting magnets to stick them on the tub because those resistors get hot.
If you're going to return them and still want led bulbs, look for canbus,, built-in resistor, or anti flicker bulbs.
Honestly, the price of led rear taillight assemblies has come down in price over the years. You can easily pick up a set for under $100 and a decent set for around $60.
