Leaking oil cooler line or am I crazy?
Treydg2003
Kentucky
Question hopefully someone here can point me in the right direction. Had my 2016 rubicon for a few weeks now. Noticed some motor oil on trans pan and very slight drip. Read into it about the oil cooler in the valley. Cleaned all residual oil I could find, can't actually see any in the valley where filer housing is, not enough to run that far anways. So I change the oil and kept an eye on it. Drive it for 3 weeks with no oil accumulated on trans pan. Take it off roading and put on some hills. Now there is the slightest amount on trans pan at the rear. With one or 2 droplets on the front trans cooler line (closest to oil pan). Still cannot see much in the valley. Btw oil at pan is very dark black and has fresh oil in it thats clean. So Question is. Could this be left over from a previous fix? And hill climbing its putting it at an irregular angle causing to drain? oil cooler? Thanks for any and all help!
