JK seems to misfire in all gears at different speeds
<blockquote data-quote="MacGuyver" data-source="post: 445135" data-attributes="member: 18877"><p>So you had the speedometer adjusted when the new tires got put on? Shift points are dependent on speedometer. Also, when is the last time you had the trans oil changed? </p><p></p><p>couple things to check that should be cheap.</p></blockquote><p></p>
[QUOTE="MacGuyver, post: 445135, member: 18877"] So you had the speedometer adjusted when the new tires got put on? Shift points are dependent on speedometer. Also, when is the last time you had the trans oil changed? couple things to check that should be cheap. [/QUOTE]
