Jeep walk possibly from tires?
JeepMama6
Pennsylvania
I am looking at a 2013 JKU, it has the jeep walk, but it also has Bridgestone duellers on it. It's has all new front end parts. The walk goes away at 60mph, my husband is hesitating on the purchase because of the walk it has. I am thinking it's the tires causing the issue as the duellers have a thick side wall and are a hard tire. Any suggestions.
Does it have a lift kit on it, a cheap lift will do that. Also over inflated tires will cause handling issues.
It doesn't have a lift on it, we had them bring the air down on the tires for my husband to test drive it. I would think the walk would get worse the faster you go if it was an alignment or part issue. We have had duellers on a truck and it had the same walk issue.
