Eras BOLD ITC
Here are the specifics to make it work (You'll need Adobe Illustrator or Photoshop)... your local FastSigns can do the final lettering to match hood lettering colors and etc.
Details -
Kerning - Metric
Tracking - 60
Horizontal Stretch 208%
Vertical Stretch 100%
Freeform adjustment - You need to add +5 degrees Horizontal after the above settings...
This removed the slight (5 deg.) slant in this font that is not prevalent in the RUBICON logo. This will cause some minor concave curvatures in the stock of the I's and R's... but unless you are cutting a letters that are 1 foot high... it should be fine.
These are close... you can adjust as necessary.. but only a trained graphics designer would
argue that you aren't right on...
