Intermittent Traction Control
Subman751
Lynch Station Virginia
Hello, I have a 2018 JK with 3.5 inch lift kit and 35x12.50R18 wheels and tires. I have been trying to fix this intermittent traction control light issue. It comes on when turning right even slightly. I have checking my battery terminals and they are tight. I replaced all four wheel speed sensors. I replaced the clock spring and still having this issue. Does anyone else have an idea of what to do at this point. I love my Jeep but this is starting to not be worth it. Any help would be appreciated.
Is your steering wheel straight? If it's canted even a little to either side, it'll trigger the traction light.
In my area, there is a road that has a really high crown. Driving down it requires you to hold a little pressure to counter the crown. And that is enough to trigger my traction light.
I have a 2016 Wrangler having same issue, changed my speed sensors issue came back had a diagnostic done on it was told Vacuum Pump Control Circuit has No Ground to Vacuum Pump..... Need to trace it but at $125 a hour was told it could take 5 min to few hours ........ Im stuck as well.
Did you read the Post right above you?
