I had to change the door Latch on my 2007 wrangler jk due to the door switch not working which is built into the door latch mechanism, the door latch also has the power door lock actuator built into it so could be a problem if your power door lock isn't working. This video would also apply if you had to change the power window motor or power window regulator because those have to come out in order to remove the door latch \ door lock actuator. A few minutes of this video had to be muted because youtube flagged it as Copywrite protection because I left the radio on even though I was talking over the radio.
