2012 cylinder 5 misfire
stewie
Michigan
Have a 2012 jeep wrangler Sahara. Throwing cylinder 5 misfire. Replaced plugs and coilpacks. Still have check engine light on. Been running injector cleaner through the system. Jeep runs fine. Any ideas?
Reactions: vaffanculo
Not being a smart alleck but did you put your scanner on and clear the code? If the misfire message is coming from where your milage is written just turn the key to the on position without starting it and press the gas pedal 3 times to the floor that usually clears all messages like change oil soon etc.If not it will still stay lit...if you don't have a scanner just take the negative battey terminal off for like 10 minutes then put back on that will rest the computer negative battery t
Reactions: tJKrider
