2013 JKU, 3.6 PentaStar, 219,000 miles .....From NC. I did a cross country trip hitting the BOH trails over the summer. In SoCal I threw a code P0344. Trans went from 5th gear to 4th gear....manually pushed it back into 5th gear and went straight to a dealer. They replaced Bank 1 Sensor. Thought all was good went on to the Rubicon. But light came on a couple hours into my drive. Needless to say I cleared the code and pushed on. This was repeated many times until I noticed the Code was popping every 2 hours of drive. I stopped in Oklahoma and had another dealer try to figure it out. They dropped in both Bank 1 and 2 sensors. Now, 4 months later, I'm starting to recognize a pattern. Once my engine gets to 27-2800 RPM, 67-69MPH Engine Light comes on, Trans drops to 4th and repeats the process every time. So I have been maintaining a speed of 65MPH on highways and watching my RPM's, in order to not throw the code. I've replaced Bank 1 and Bank 2 sensors again. I am tempted to replace the pigtail in hopes its something electrical. But I am also concerned of the CAM walking or Timing Chain being loose.
Please - if you've been able to fix this help guide me to the correct fix!
