Headlights / wipers won't turn off
AmyD
Tampa, FL
Greetings! Last week I got caught in a downpour in my naked '15 JKU. Now I have the following issues:
  • Headlights won't turn off
  • Wipers won't turn off
  • Turn signals don't work
Buttons on left side of steering wheel don't work (i.e. Step), but buttons on the right side (cruise control) DO work
Buttons on both sides of the back of the steering wheel to control the radio don't work.
Someone mentioned a multi-function switch. When I googled, I found that it's the left side turn signal switch. But I'm wondering if replacing that will fix ALL my problems? Especially since the wipers are controlled by the right-side lever.
Has this happened to anyone else? If so, what are all the components you had to replace to resolve? Thought I'd ask here before I go to a shop and they tell me I need to replace all my steering column components when it could possibly be something as simple as a fuse (although I'm sure I won't get that lucky).
Thanks in advance.
Yep, sounds to me like your MFS (multi-function switch) is bad. These are classic symptoms of a bad MFS.
