Two years ago I purchased these headlights and installed them.
7 Inch LED Halo Headlights with Turn Signal Amber White DRL Compatible with 2007-2017 Jeep Wrangler JK JKU
They’ve been working great up until just recently when the passenger side directional ring around the headlight stop flashing. If I turn the headlights on then the right or passenger side directionals don’t work at all in the front neither the ring or the directional itself. As part of my troubleshooting, I repeat I switched headlights and the problem still exists. I switched wire harnesses that came with those headlights and the problem still exists still on the passenger side. It’s not the headlight itself it’s not the wire harness that came with those headlights. The problem seems to lie somewhere between the headlight and the fuse box or headlight switch. Does anyone have any suggestions?
