Headlight bubbled
<blockquote data-quote="Dirty Dog" data-source="post: 454709" data-attributes="member: 24042"><p>Evap purge leak is nearly always the cause. There's a purge valve under the hood, a couple hoses between that valve and the fuel tank, with a cannister in the middle. They crack and leak all the time. Easy repair.</p></blockquote><p></p>
[QUOTE="Dirty Dog, post: 454709, member: 24042"] Evap purge leak is nearly always the cause. There's a purge valve under the hood, a couple hoses between that valve and the fuel tank, with a cannister in the middle. They crack and leak all the time. Easy repair. [/QUOTE]
Headlight bubbled
