Has anyone recently purchased an OEM flip key?
kellytan1026
El Dorado Hills, CA
I just recently bought a 2017 JK with only 1 key. Has anyone recently purchased, programmed and cut a flip key fob? I do see older threads where the links are outdated. Just don’t like the old school injection transponder keys.
This site contains affiliate links for which Jeep Wrangler JK Forum may be compensated.
I bought (2) new flip keys from FleaBay, had them cut, used jScan to program them, and my remote start works - sometimes.
I have to press all (3) button at the same time to get it to work, and that usually causes me to press the panic button first, which disables the remote start circuit because the ECU responds just like if an alarm had been set off.
My Charger was similarly equipped; if there is a CEL, an active code, the panic button had been set off, or a few other reasons it would not allow a remote start to function.
