I drove through a deep enough water hole offloading and got stuck. It still ran in idle just fine for hours waiting on a tow truck. There was a few inches of water inside the cab till I got it pulled out. It wouldn't go into gear unless I used the bypass. Even then it would go into drive but the indication didn't show drive. Once I got on dry land it road fine for a about 2 miles then started cutting out. The oil light did come on for a few seconds before I stopped and shut it off. Had it towed from there. Is it totaled or is there any hope it can be repaired. Thanks!
