Have some quarantine-time and want to tune up my wife's new-to-us 2008 Jeep Wrangler JK 2-door.
Nothing really wrong, just want to go through it to make sure everything is OK. For all I know, all of this service was done by the PO and I will be wasting my time and money. I just got it inspected by a competent mechanic and told him to really go through it and check it out to see if anything is needing repair, and he gave me basically a clean bill of health, except for bad rear shocks, which I replaced already. Fronts seem OK and appeared newer than the rears.
Thinking this should include:
Spark plug replacement
EGR Valve
PCV Valve
Wires and coil packs?
check all fluids, possible flush and fill of any that are suspect, esp. radiator coolant (use correct type)
Seafoam into brake/vac line
check and clean battery terminals/tightness
check engine ground strap
Check tire pressures (taking it in to have the TPMS sensors reinstalled soon)
Anything else?
Don't want to start WW3, but what oil does anyone recommend for an engine with 150K on it?
I am planning to order a hayne's or chilton's or other shop manual - which does anyone recommend?
Thank you - I did search but did not find a "comprehensive tune up guide"...apologies if there is one.
If I find anything I don't want to tackle myself, I'll bring it to the shop since I plan to have htem install the TPMS sensors in the current rims/tires at the next oil change interval in about 2000 miles.
JIM
EGR Valve
PCV Valve
Anything else?
JIM
