Hello,
While driving & punching the gas, sometimes I would lose power for a couple of seconds. Once I let off the gas pedal & give gas again the car regains power instantly. Last weekend on the highway the car loss total power when punching the gas no matter that I let off the gas pedal & tried re-accelerating. The car did not respond to anything, which caused me to pull over. I attempted to restart the car a couple times, but it wouldn't kick over. While waiting for the tow truck, I later retried turning on the car & it started as normal. This was approximately 15min after the car shut off. This was the 1st time the car shutoff. The other occurrences in the past when I noticed loss of power, it has not frequent, since it doesn't happen multiple times when driving daily.
After my car shutoff I took it to a mechanic. The mechanic stated there were no error codes coming up when trying to diagnosis the issue. The mechanic did a throttle body relearn as the 1st step to diagnosing this issue. I am trying to narrow down the problem to avoid having this issue occur again so I appreciate your input with solving this issue.
Thank you for your help!
