Wandering around the road,new upper and lower ball joints,new drag link, alignment,new shocks,new OEM tires and wheels,it does have a 1.5 inch leveling kit installed by previous owner,any help
Found a bad wheel bearing on drivers side rear,gonna replace it and see if it helps
Another question
Can the tpms system be unhooked,don't need it, would like light off
I have notHave you checked to see if the axles are centered under the Jeep?
New Track Bar resolved my wandering.Wandering around the road,new upper and lower ball joints,new drag link, alignment,new shocks,new OEM tires and wheels,it does have a 1.5 inch leveling kit installed by previous owner,any help
Ok I'll keep that in mind,if the rear wheel bearing doesn't fix itNew Track Bar resolved my wandering.
Can you expand on this please? Was the OEM damaged or did you upgrade? If the former, what was the issue?New Track Bar resolved my wandering.
