Just got a salvaged jk. Hit pretty hard on the right front wheel. It has lift pucks above the springs (might have caused the wreck) with no other aftermarket parts. I assume track bars, shocks, trailing arms sway bar links all need to change with the lift. Am i correct? Axle tube is bent slightly from top trailing arm bracket out. Gonna try to staighten that if possible. With a hard hit like this Im thinking adjustable track bars and trailing bars to correct for any small defects. Any thoughts?
