Evap purge valve lines
Guardian 3
Texas
I replaced the evap purge valve on my 13 JK. When removing the two lines, the retainers broke on both of them. Not the colored clips you remove first but the ones that just slide over so you can remove the line from the valve. Does anyone know where I can find replacement retainers? I saw some on Amazon but there were several different sizes and I'm not sure which size is correct. Any ideas?
